Would you accept this
Coffeecup
Coffeecup Member Posts: 25
edited September 2016 in Strictly Steam
...in your own house - new boiler sections delivered in rusty condition - is it ok? - system is 1 pipe steam - have seen so many posts about preventing rust in boiler seems weird to be starting off like this. any thoughts? - thank you.
  • Fred
    Fred Member Posts: 8,542
    It's just surface oxidation. It's fine. Any cast iron will do that when exposed to humidity/wet conditions and has no protective oils/gels on it (which you don't want on boiler block components, other than those that are required for any machining, which already requires skimming))
    kcoppCharlie from wmass
  • warno
    warno Member Posts: 229
    I don't know anything about stream boilers but I know about metals. Like Fred said, it's just surface rust. A quick once over with a wire ball on a drill will knock that all off.
    Charlie from wmass
  • Coffeecup
    Thank you very much Fred - helps a ton to hear that....my co-op board asked me if I could find out about this. Thanks again to you and to this incredible forum.
    Erin Holohan Haskell
  • Coffeecup
    Thank you Warno.
  • ChrisJ
    ChrisJ Member Posts: 16,858
    Doesn't matter it would look like that after the first season anyway no matter what you do. All is well.
  • Coffeecup
    Thanks Chris, I was wondering if that would be the case.
  • Fred
    Glad we could put your mind at ease. Have a good one!
  • ChrisJ
    Here's a shot of the top of my 5 year old block. That was all nice and gray when I put it in.
    Once it rusts, in theory that acts as a protective layer to an extent.
    Charlie from wmass
    Steamhead Member Posts: 17,899
    Weil-McLain 6-80?
    Consulting
    JohnNY
  • Coffeecup
    Thanks Fred, ...peace of mind, nothing quite like it ...good one to you too.
  • Coffeecup
    Interesting Chris, thank you - good to know what to expect.
  • Coffeecup
    @Steamhead ...exactly correct. 1983sf of steam, 1880 EDR, replacing boiler that put out over 4000sf. Going to gas with PowerFlame lo/hi/lo burner.
  • Dave0176
    Dave0176 Member Posts: 1,178
    If this is the job ASM Mechanical is doing, your in good hands, it'll be a thing of beauty when finished.
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    Specializing in Steam Heating, Serving the residents of New Jersey
    https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
    https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
    Paul S_3
  • Coffeecup
    Hi Dave, yes it is, and yes it will be - have full confidence in ASM - am more than excited about what's about to go down in our boiler room. Without this forum I could never have done this - as in understand and appreciate what they are about to do for us. My question was simply bc the board put me on the spot, asked for more information - it's been a long haul convincing them to do this, and as the board pres. and main instigator it's a lot easier for me, and better for everyone, if everyone in the building is happy. I have no doubt it will be an amazing installation. Can't wait.
