Commercial DHW
Dan Foley
Member Posts: 1,268
This is one Brian, Poppy and crew started up today.
It is a DHW system for a 47 unit apartment building.
We started this back in January and finished up today.
3
Impressive!
Where do you get the stickers that show whats in the pipe?0 -
I order them from pipemarker.com
Makes sense. Thanks.0
Nice work, Dan (as usual). Another ETV I see.0
Nice reverse return, my favorite way to pipe multiple loads. How much total capacity do you have there? DHW and boiler inputs?
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Beautiful work, Dan. You can really see the time and care that went into this project. Kudos to you and your team!
President
HeatingHelp.com0 -
But you have to put them on the inside of the pipes, so the water knows which way to go.........Dan Foley said:I order them from pipemarker.com
Consulting1 -
Mighty fine looking piece of work there Dan.
- 167 Indoor-Air Quality
