Commercial DHW
Dan Foley
Dan Foley Member Posts: 1,268
This is one Brian, Poppy and crew started up today.
It is a DHW system for a 47 unit apartment building.
We started this back in January and finished up today.
Harvey RamerkcoppSolid_Fuel_Man
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,289
    Impressive!
    Where do you get the stickers that show whats in the pipe?
  • Dan Foley
    I order them from pipemarker.com
  • Harvey Ramer
    Makes sense. Thanks.
  • SWEI
    SWEI Member Posts: 7,342
    Nice work, Dan (as usual). Another ETV I see.
  • Solid_Fuel_Man
    Nice reverse return, my favorite way to pipe multiple loads. How much total capacity do you have there? DHW and boiler inputs?
    Taylor
  • Dan Foley
    Two Viessmann boilers @ 530k btu/hr input each.
    Four 120 gal storage tanks.
    The system it replaced had one 385k btu water heater and one 500 gal. Storage tank.
    Solid_Fuel_Man
  • EzzyT
    EzzyT Member Posts: 1,380
    Nice and clean Job Dan
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    Beautiful work, Dan. You can really see the time and care that went into this project. Kudos to you and your team!
    President
    HeatingHelp.com
  • Dan Foley
    Thanks all for the nice comments. Credit goes to Brian, Poppy and crew who worked on this one.
    SWEI
    Steamhead Member Posts: 18,572
    But you have to put them on the inside of the pipes, so the water knows which way to go......... >:)
    Consulting
    SWEI
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Mighty fine looking piece of work there Dan. :)
