Steam Professional in Southeastern CT?
If anyone knows of a steam contractor in the Southeastern CT area I would love their contact information. That way I have some one to call if a problem should arise. Thanks!
Southeastern CT Steam Heat Lover
One Pipe Steam, roughly 0.5 psi
2023 Burnham MST-396
I could do an extensive evaluation and printed report of your system and, while I wouldn't be your servicing contractor, I could help you vet any company local to you if that's of any interest.
Best,
John Cataneo
www.72fmechanical.com
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
I'm in the field constantly so it's often best to send me an email at John@72Fmechanical.com
Classes1 -
**BUMPING THREAD in a time of need.**
Well everyone, the inevitable time of need has happened...
Same roughly 10 year old New Yorker CL4-210SE boiler, by the way.
Long story short. I noticed that this heating season I have been adding FAR more make up water than previous seasons. I have zero visible water leaks in the basement. I did notice two failed radiator vents, replaced them. This lowered the frequency of adding make up water but not by much. On Monday I had @New England SteamWorks out for a system inspection and service. They found my leak after filling the the entire boiler, most likely above the water line so I have been losing steam up the chimney.
I believe they are still working up a quote to replace the boiler. Although I'm not sure. The kicker is their distributors won't deliver a boiler to Connecticut at the current time. Hopefully perhaps that will change in the coming months. I am by no means in an urgent rush as the boiler is heating just fine as long as I babysit the sight glass daily.
All that being said, I am still having trouble finding a much more local Plumbing and Heating Professional that will work steam.
I am in Southeastern Connecticut, New London County, Preston, CT.
In the event @New England SteamWorks can't figure out a way to make a replacement happen in Connecticut the coming months I would like to have a contingency plan.
If anyone happens to be in the general area and can recommend a steam professional that actually services Connecticut I would certainly appreciate it.
This wall is a priceless wealth of knowledge and experience and I can't thank you all enough! Cheers!US Navy Senior Chief Submariner
2023 Burnham MST-3961 -
Check with Charles Garrity (Garrity Plumbing and Heating) based in Springfield, MA. I believe he will travel throughout CT. He put our new boiler and added heat to a wing on our house. I got his name from this website. Top notch guy.3DPhamily said:**BUMPING THREAD in a time of need.**
This wall is a priceless wealth of knowledge and experience and I can't thank you all enough! Cheers!1 -
3DPhamily said:@Dave_61 will do! I am running down a few different options. I appreciate it!1
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
