Steam Professional in Southeastern CT?
If anyone knows of a steam contractor in the Southeastern CT area I would love their contact information. That way I have some one to call if a problem should arise. Thanks!
Southeastern CT Steam Heat Lover
One Pipe Steam, roughly 0.5 psi
2023 Burnham MST-396
I could do an extensive evaluation and printed report of your system and, while I wouldn't be your servicing contractor, I could help you vet any company local to you if that's of any interest.
Best,
John Cataneo
www.72fmechanical.com
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
I'm in the field constantly so it's often best to send me an email at John@72Fmechanical.com
Classes1 -
**BUMPING THREAD in a time of need.**
Well everyone, the inevitable time of need has happened...
Same roughly 10 year old New Yorker CL4-210SE boiler, by the way.
Long story short. I noticed that this heating season I have been adding FAR more make up water than previous seasons. I have zero visible water leaks in the basement. I did notice two failed radiator vents, replaced them. This lowered the frequency of adding make up water but not by much. On Monday I had @New England SteamWorks out for a system inspection and service. They found my leak after filling the the entire boiler, most likely above the water line so I have been losing steam up the chimney.
I believe they are still working up a quote to replace the boiler. Although I'm not sure. The kicker is their distributors won't deliver a boiler to Connecticut at the current time. Hopefully perhaps that will change in the coming months. I am by no means in an urgent rush as the boiler is heating just fine as long as I babysit the sight glass daily.
All that being said, I am still having trouble finding a much more local Plumbing and Heating Professional that will work steam.
I am in Southeastern Connecticut, New London County, Preston, CT.
In the event @New England SteamWorks can't figure out a way to make a replacement happen in Connecticut the coming months I would like to have a contingency plan.
If anyone happens to be in the general area and can recommend a steam professional that actually services Connecticut I would certainly appreciate it.
This wall is a priceless wealth of knowledge and experience and I can't thank you all enough! Cheers!US Navy Senior Chief Submariner
2023 Burnham MST-3961 -
Check with Charles Garrity (Garrity Plumbing and Heating) based in Springfield, MA. I believe he will travel throughout CT. He put our new boiler and added heat to a wing on our house. I got his name from this website. Top notch guy.3DPhamily said:**BUMPING THREAD in a time of need.**
This wall is a priceless wealth of knowledge and experience and I can't thank you all enough! Cheers!1 -
No problem. Definitely get someone recommended by this forum. As you probably know, there aren’t that many guys that know steam anymore. There are so many horror stories of terrible installations. BTW, where are you in SE CT? I grew up in the Stonington area.3DPhamily said:@Dave_61 will do! I am running down a few different options. I appreciate it!1
- 128 Chimneys & Flues
