Prepiped 3" drop header
EzzyT
EzzyT Member Posts: 1,368
Prepiped the 3" drop header for tomorrow's steamer repipe
E-Travis Mechanical LLC
Etravismechanical@gmail.com
201-887-8856
Steve MinnichChrisJSWEIPaul S_3jonny88New England SteamWorksDave0176
«1
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Are the nipples on the drops 6" in length?
    Can that vary?
    What is the purpose of the ball valves? Isolation, I assume?
    Steve Minnich
  • EzzyT
    Stephen those are 3"x12" nipples on the drop/risers and will have another 3"x12" nipples with the union in between them. Yes they can vary but wouldn't suggest no let less then 24" in total from the top of the boiler. The ball valves (king valves) along with the return valve purposes are for when performing the annual boiler service they are shut and fire the boiler to buildup about 5 psi and use the pressure in the boiler to flush out the mud and rust out of the bottom of the boiler
    201-887-8856
    Steve MinnichPaul S_3
  • Steve Minnich
    Thanks EzzyT - one more question.
    Is the union on the horizontal header necessary?
    Steve Minnich
  • EzzyT
    No it's not, I put it there otherwise the header would've been to cumbersome to handle all in one piece
    201-887-8856
  • EzzyT
    I'll post more pictures and info when I'm done with the repipe
    201-887-8856
  • Steve Minnich
    Cool. Thank you. I have one in a few weeks where I'm going to use a drop header. Spent 4 hours in steam books this afternoon. It's amazing all of the subtle differences I saw in various resources.
    Steve Minnich
    Paul S_3SeanBeans
  • EzzyT
    Oh cool I'm sure the piping set up will be just as neat and clean as your hot water boilers. Its amazing what the dead men came up with not that much to work with. Have read any of the literature on the vapor systems?
    201-887-8856
  • Steve Minnich
    Just a little so far. Focusing on basic one pipe now. The light is starting to come on : ).
    I saw a reference to Gerry Gill pdf's on another thread. Can someone tell me where to find those? I know there's a ton of information and videos on his website but I didn't see any pdf's.
    Steve Minnich
  • Fred
    Fred Member Posts: 8,542
    It is available in the Store. It is a PDF that gives the capacity of various vents, both main and radiator as well as pipe, by diameter. It costs $10.00 and that money goes to charity. It's called "Balancing a Steam System, Using a Venting Capacity Chart. "
    Steve Minnich
  • EzzyT
    Stephen you can find it under the link system helper-steam-air venting
    201-887-8856
    Steve Minnich
  • SWEI
    SWEI Member Posts: 7,348
    Anyone know if Gerry has added the Big Mouth traps to the PDF?
  • Fred
    edited September 2016
    I don't think so yet but the B&J Big Mouth vents at 3.6 CFM and the B&J Vari-Vent Vents at up to 2.5 CFM
    EDIT: The Big Mouth is 3.6 CFM, not 3.5
  • Danny Scully
    Danny Scully Member Posts: 1,462
    @EzzyT, you ever think about mounting termination flanges and starting from there?
  • Paul S_3
    Paul S_3 Member Posts: 1,288
    Nice drop header as always @EzzyT
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • EzzyT
    Danny the unions or flanges are the last part of the header piping to be installed to start from them wouldn't make any sense
    201-887-8856
  • EzzyT
    Thanks Paul
    201-887-8856
  • Danny Scully
    @EzzyT, I'm thinking about building the header onsite, where they would be the first part of the header. Clearly your method works, I was just thinking out loud. Looking forward to the completion pictures.
  • EzzyT
    Oh I hear yeah, 99% of the time when I'm piping the header either at the shop or on the job it's all done on the vise then carried over and connected via unions or flanges
    201-887-8856
  • Sweet. I always enjoy seeing a "before" pic if you wouldn't mind when you go back. Looking forward to finished pics as well.
    newenglandsteamworks.com
  • ChrisJ
    ChrisJ Member Posts: 16,854
    I've spent two weeks trying to figure out how to run the duct work in my attic, with the help of two very knowledgeable people and I still don't know what I want.
    At least steam pipes are small and fit!
    Duct work seems like trying to fit 2 pounds of baloney in a 1 pound bag. Extra points if you know where that's from. :)
    @EzzyT Beautiful work as always.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Wow. That's as old as I am. ;-)
    ChrisJ
  • EzzyT
    Before pictures
    201-887-8856
  • Paul S_3
    nice job....really nice job @EzzyT .....where do you get your loop hangers from? i cant find those particular ones ....just clevis style
    347-692-4777
    ASMHVACNYC.COM
  • EzzyT
    Thanks @Paul S. Carpenter and Paterson plus all the supply houses I deal with carry them
    201-887-8856
  • Fred
    Wow! looks Great!
  • Terrific work @EzzyT ! That will make for a very happy homeowner.
  • EzzyT
    Thanks, @RI_SteamWorks, yeah the home owner is thrilled how everything has come out so far.
    201-887-8856
  • EzzyT
    Thanks @KC_Jones
    201-887-8856
  • You and @Dave0176 both have some real nice headers up right now. Tough to pick a winner with such nice work. But I did find one glaring difference :) :
    So, Ezzy, I am here to help!
    1-1/2" Niple Rack
    2" Nipple Rack
    Anyone ever finds a line on larger nipple racks, I am all ears.
  • ChrisJ
    Uhoh, he's calling someone out on a Homer bucket.
    EzzyTCanucker
  • Not calling out! Just trying to have a little fun and be helpful at the same time. The larger nipple racks are not the easiest to source...
  • ChrisJ
    5 gallon buckets are the ultimate multitool
    They carry your tools
    They carry your nipples
    They carry your a** during lunch
    They work as a portable toilet
    They are a good stool
    They drain your boilers
    They catch your leaks
    I'm sure I forgot 20 things.
    Oh, they also carry joint compound fairly decent too. :)
    Paul S_3
  • Hap_Hazzard
    They roll pretty well too. This summer I had some work to do up on my roof, so I put all the tools I needed in a bucket and hauled it up by a rope after I'd climbed up the ladder. As I was trying to hook the lifeline up to my safety harness, I kicked it over and watched it roll down the roof, scattering tools, nails and screws as it went, and crashing onto the driveway a few feet from my car.
    SWEI
  • Dave0176
    Dave0176 Member Posts: 1,178
    The nipple racks are awesome, or as some guys around here call them, "bunny boxes" lol, I got 1/2-3/4, 1-1/4, 1-1/2, and 2" the rest of the stuff goes into the 4 gallon milk crates. I have about 8 of them for the fittings. AFAIK I never seen anything larger then 2" for nipples.
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    Specializing in Steam Heating, Serving the residents of New Jersey
    https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
    https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
  • EzzyT
    I have them up to 11/4" I'll have to pick up the 11/2" and 2"
    201-887-8856
  • Dave0176
    I think I got them at Amazon @EzzyT
  • Steve Minnich
    I got mine from Porter Pipe and Supply. Great company. Great inventory. Great personnel. Great service.
    Yeah. I like'm.
    Steve Minnich
  • EzzyT
    201-887-8856
