Prepiped 3" drop header
EzzyT
Member Posts: 1,367
Prepiped the 3" drop header for tomorrow's steamer repipe
7
Are the nipples on the drops 6" in length?
Can that vary?
What is the purpose of the ball valves? Isolation, I assume?Steve Minnich0 -
Stephen those are 3"x12" nipples on the drop/risers and will have another 3"x12" nipples with the union in between them. Yes they can vary but wouldn't suggest no let less then 24" in total from the top of the boiler. The ball valves (king valves) along with the return valve purposes are for when performing the annual boiler service they are shut and fire the boiler to buildup about 5 psi and use the pressure in the boiler to flush out the mud and rust out of the bottom of the boiler2
Thanks EzzyT - one more question.
Is the union on the horizontal header necessary?Steve Minnich0 -
No it's not, I put it there otherwise the header would've been to cumbersome to handle all in one piece0
I'll post more pictures and info when I'm done with the repipe0
Oh cool I'm sure the piping set up will be just as neat and clean as your hot water boilers. Its amazing what the dead men came up with not that much to work with. Have read any of the literature on the vapor systems?0
Just a little so far. Focusing on basic one pipe now. The light is starting to come on : ).
I saw a reference to Gerry Gill pdf's on another thread. Can someone tell me where to find those? I know there's a ton of information and videos on his website but I didn't see any pdf's.Steve Minnich0 -
It is available in the Store. It is a PDF that gives the capacity of various vents, both main and radiator as well as pipe, by diameter. It costs $10.00 and that money goes to charity. It's called "Balancing a Steam System, Using a Venting Capacity Chart. "Stephen Minnich said:Just a little so far. Focusing on basic one pipe now. The light is starting to come on : ).
I saw a reference to Gerry Gill pdf's on another thread. Can someone tell me where to find those? I know there's a ton of information and videos on his website but I didn't see any pdf's.1 -
Stephen you can find it under the link system helper-steam-air venting1
Anyone know if Gerry has added the Big Mouth traps to the PDF?0
I don't think so yet but the B&J Big Mouth vents at 3.6 CFM and the B&J Vari-Vent Vents at up to 2.5 CFM
EDIT: The Big Mouth is 3.6 CFM, not 3.50 -
@EzzyT, you ever think about mounting termination flanges and starting from there?0
Nice drop header as always @EzzyTASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Danny the unions or flanges are the last part of the header piping to be installed to start from them wouldn't make any sense0
@EzzyT, I'm thinking about building the header onsite, where they would be the first part of the header. Clearly your method works, I was just thinking out loud. Looking forward to the completion pictures.0
Oh I hear yeah, 99% of the time when I'm piping the header either at the shop or on the job it's all done on the vise then carried over and connected via unions or flanges0
Sweet. I always enjoy seeing a "before" pic if you wouldn't mind when you go back. Looking forward to finished pics as well.New England SteamWorks
newenglandsteamworks.com0 -
I've spent two weeks trying to figure out how to run the duct work in my attic, with the help of two very knowledgeable people and I still don't know what I want.Stephen Minnich said:Cool. Thank you. I have one in a few weeks where I'm going to use a drop header. Spent 4 hours in steam books this afternoon. It's amazing all of the subtle differences I saw in various resources.
At least steam pipes are small and fit!
Duct work seems like trying to fit 2 pounds of baloney in a 1 pound bag. Extra points if you know where that's from.
@EzzyT Beautiful work as always.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Wow. That's as old as I am. ;-)ChrisJ said:2 pounds of baloney in a 1 pound bag.
Before pictures1
Thanks Chris
First day repiped the boiler and about 80' of wet returns.
Going back next week to finish up by cleaning up the mains venting, Vxt water feeder, stage firing set up, skim and combustion Analysis6 -
nice job....really nice job @EzzyT .....where do you get your loop hangers from? i cant find those particular ones ....just clevis styleASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Thanks @Paul S. Carpenter and Paterson plus all the supply houses I deal with carry them0
Wow! looks Great!0
Terrific work @EzzyT ! That will make for a very happy homeowner.New England SteamWorks
Thanks, @RI_SteamWorks, yeah the home owner is thrilled how everything has come out so far.0
I know winter is getting closer when the boiler porn ramps up on the wall. Awesome work!6
You and @Dave0176 both have some real nice headers up right now. Tough to pick a winner with such nice work. But I did find one glaring difference
So, Ezzy, I am here to help!
1-1/2" Niple Rack
2" Nipple Rack
Anyone ever finds a line on larger nipple racks, I am all ears.New England SteamWorks
Not calling out! Just trying to have a little fun and be helpful at the same time. The larger nipple racks are not the easiest to source...New England SteamWorks
5 gallon buckets are the ultimate multitool
They carry your tools
They carry your nipples
They carry your a** during lunch
They work as a portable toilet
They are a good stool
They drain your boilers
They catch your leaks
I'm sure I forgot 20 things.
Oh, they also carry joint compound fairly decent too.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
They roll pretty well too. This summer I had some work to do up on my roof, so I put all the tools I needed in a bucket and hauled it up by a rope after I'd climbed up the ladder. As I was trying to hook the lifeline up to my safety harness, I kicked it over and watched it roll down the roof, scattering tools, nails and screws as it went, and crashing onto the driveway a few feet from my car.Just another DIYer | King of Prussia, PA
The nipple racks are awesome, or as some guys around here call them, "bunny boxes" lol, I got 1/2-3/4, 1-1/4, 1-1/2, and 2" the rest of the stuff goes into the 4 gallon milk crates. I have about 8 of them for the fittings. AFAIK I never seen anything larger then 2" for nipples.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
I have them up to 11/4" I'll have to pick up the 11/2" and 2"0
I think I got them at Amazon @EzzyTDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I got mine from Porter Pipe and Supply. Great company. Great inventory. Great personnel. Great service.
Yeah. I like'm.Steve Minnich0 -
Thanks @Dave0176 and @Stephen Minnich0
- 109 Chimneys & Flues
- 974 Plumbing
- 386 Solar
- 17 Recall Announcements
