What's this called?
Hilly
Member Posts: 429
Is this fitting more of a HVAC style fitting? I have seen them a few times over the years but only ever on hydronics and never in a plumbing system. Friend sent me his find today because he'd never seen such a creature before.
Perhaps it's a supply and return tee?
http://www.nibco.com/Fittings/Metal-Fittings/Pressure-Fittings/Cast-Copper-Pressure-Fittings/711-A-Supply-and-Return-Tee-C-x-C-x-C-Cast/
If there is a pump on the boiler, it looks to be a primary secondary loop with the branch secondaries off either side
Although pipe sizing is suspect?Bob "hot rod" Rohr
Living the hydronic dream0
- 62 Biomass
