What's this called?
Hilly
Hilly Member Posts: 429
Is this fitting more of a HVAC style fitting? I have seen them a few times over the years but only ever on hydronics and never in a plumbing system. Friend sent me his find today because he'd never seen such a creature before.
  • ChrisJ
    ChrisJ Member Posts: 17,070
    Looks like a sloppy mess to me.
    However that's not helpful at all, let's see if I can get Charles Garrity to have a look.
    Hilly
  • ChrisJ
  • bob_46
    bob_46 Member Posts: 813
    I believe that's a watchamacallit I've made lots of them. If you need a special fitting or are too far from the supply house you break out the hole saw and the sil-fos walla a custom fitting.
    SWEI
    hot_rod Member Posts: 26,594
    If there is a pump on the boiler, it looks to be a primary secondary loop with the branch secondaries off either side
    Although pipe sizing is suspect?
  • Hilly
    @hot rod maybe it a textbook but certainly not around these parts hahaha. When trying to google I did find them on Allibaba from China and they were under HvAC but everything else I couldn't read. So thought maybe it was a specialized fittings for HVAC guys.
