Dug this out of a box today
Steve Minnich
Member Posts: 2,868
Pulled this off of a boiler I replaced about 20 years ago. I believe the boiler predates WWII because of some of the castings on all of the burners. The signs that were cast were accepted socially pre-WWII because it had a different meaning.
Then, a certain psychopath got a hold of it and changed its meaning entirely.
I may have learned that from Dan?
Steve Minnich
6
It was a Burnham I'm assuming?0
Everything on it said Bryant. I still have the data plate and it said Bryant manufacturing as well.Steve Minnich0
Wow, how did I miss that on the gauge? Burnham had a boiler called the Swasteeka, I've seen a few of those.0
I'll post a picture tomorrow. I kept the valve, 3/8" pipe assembly, and orifice for one of the burners. Two swastikas on that one short piece. I had six of them but it made me uncomfortable having them. On each of the cast iron sections, there was a swastika too.Steve Minnich0
OK, I have looked at this 10 different times over the last 2 days and don't see what I had anticipated would be there. Just from reading your text I figured what to look for but don't see it.
So point it out for an old guy with the beginning of cataracts.
I have even undressed and gutted the dog several times looking for this.2 -
Maybe you posted the wrong pic?All Steamed Up, Inc.
Consulting0 -
What we're referring to is casted into the boiler sections and isn't pictured.0
Yes, it had a very different meaning to everyone before WWII.
Here's the inside of the Spirit of St Louis's propeller spinner, though I believe it wasn't used as it cracked before he left for France.
I believe it was a symbol of good luck before WWII.
At one time I was told that symbol is of Native American origin. It was used in mirror image at a Boy Scout camp I attended back in the '50s.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
https://en.wikipedia.org/wiki/Swastika
The swastika (also known as the hakenkreuz, gammadion cross, cross cramponnée, pellahydren, or tetraskelion) (as a character: 卐 ) is an ancient religious symbol that generally takes the form of an equilateral cross, with its four legs bent at 90 degrees.[1][2] It is considered to be a sacred and auspicious symbol in Hinduism, Buddhism, and Jainism and dates back to before the 2nd century BC.[3] It continues to be commonly used as a religious symbol in Indian religions such as Hinduism, Buddhism, and Jainism.
@Pumpguy looks like it's from India.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I'll be at the shop within a couple hours. I'll post the part with the symbol I was referring to then. Sorry for the confusion.Steve Minnich0
Consulting1 -
I see the name Fred Rohr on the propellor. Any relation to Hot Rod do you suppose?
Rick0 -
Consulting0 -
You could probably sell those on eBay as German collectibles...0
Hi: That symbol was used by Crane Company also. You'll see it on their older valves. If I remember correctly, it's listed as a trademark in their catalog from 1925.
Yours, Larry0 -
Here's the boiler data plate. Looks like it may be from '45 which would be a little late to still use it.Steve Minnich0
The Hull town hall had a tile floor that had swastika's laid into the pattern when it was installed.
Massachusetts Town Votes To Remove Indian Swastikas
Reuters
Published: January 14, 1990
HULL, Mass., Jan. 13, 1990— Officials of this seaside community near Boston have decided to remove a floor whose tiles have American Indian swastikas inlaid in them. The floor was laid in Town Hall 66 years ago, before the Nazis adopted the ancient mystic emblem.
Selectmen voted Wednesday night to carpet over the mosaic floor after protests from the Jewish Defense League. It will eventually be altered to eliminate the swastikas.
For American Indians, the swastika is an emblem of peace and good luck. Nazi Germany saw to it that the crooked cross was associated with virulent anti-Semitism and the deaths of six million Jews.
Hull, a coastal community about eight miles from downtown Boston, is home to about 1,000 Jews, town officials said. The inlaid floor was first criticized six years ago by a local newspaper columnist who is Jewish.
3PSI gauge0 -
That symbol was actually used as a mechanical symbol on a lot of pre WW2 equipment and had no connection whatsoever to Nazi Germany at that time.
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
