Pump to empty
John Mills_5
Member Posts: 952
Since old WHs don't like to drain, what kind of pump do you boys use to help them along? Thanks
just that standard cheapo plug in that has hose connections on each side. Probably bought it from HD years ok
Valve off the cold line, air compressor coupled to the hot line.
Did you pull the drain valve?0 -
Liberty 331. pump.0
air compressor was my favorite method. pump to 100 psi and watch them drain!
Agree, remove the bottom drain and put a nipple or hose adapter on. those round plastic type of drains plug quickly, even the brass compression style.Bob "hot rod" Rohr
Thanks guys!0
