how many btus can i get out of my domestic hot water coil
Joseph_4
Joseph_4 Member Posts: 319
Hi,
Does anyone know the proper method to figure out how many btus that you can get out of a hot water coil. I have a steam boiler with a coil that is being used for a baseboard hotwater loop. I want to add more baseboard and would like to know how to figure out the max btus that i can get out of the coil
Thanks
Joe
HHI Services
  • Joseph_4
    Hi. could you explain how you arrive at that number. 80k is a lot there are complete cast iron boilers in the 38-70k range. Another question- assuming your numbers are correct,
    if the oil nozzle is a 1.25 nozzle and the steam load is say 140 btu out, if I pipe 80k baseboard on that coil will I have less btu available for my steam rads?
    Thanks
    Joe
  • Paul48
    Paul48 Member Posts: 4,469
    Prioritize and use an aquastat for the baseboards. Run either, or, not both at once.
