Installing a hot water heating system without a plumbed in water supply
Bart32
Member Posts: 2
I am planning to install a radiant floor heat system in my shop which does not have a direct water supply. I would like to use a small gas wall mounted boiler and am wondering how to handle the feed water supply. I cannot easily bring a frost proof water line from my house so I am thinking that a water tank of some type could be used to supply water to the system. Since it is a closed system I presume it shouldn't need much water and perhaps all I need to do is top it off occasionally. I can run a temporary hose to fill the system as needed or use a small pump to inject water from a bucket.
It seems to me that if I used a large enough pressure tank it could maintain the necessary pressure even with a loss of several gallons of water.
In a shop, you may consider using glycol also. You could also use a glycol fill tank, like Axiom and others. They get used with water or glycol.Bob "hot rod" Rohr
Living the hydronic dream1 -
To be fair, Axiom really does make great stuff.
In this particular case, an oversized expansion tank can probably cover it.0 -
If the potential loss you want to cover is several gallons, consider a PIG.
A separate expansion tank, filled to 80 psi and attached to a pressured reducing fill valve. With a small #30 tank you can get around 3 gallons, or a #60 about double that.
Expansion tank, Webstone purge port valve, boiler fill valve, wash machine hose and adaptersBob "hot rod" Rohr
Thank you all for your very helpful comments and suggestions. I am not expecting any fluid loss as this is a new floor installation and shouldn't have any leaks. I will be using antifreeze in the system since it won't be heated at all times. I will probably just use an over-sized expansion tank and, if it loses a little pressure, I'll top it off with a hose from the house.0
Yeah, if the system is tight, no worry. Within a few weeks of operation all air should purge itself out. Use a micro bubble type air purger, glycol is tough to scrub micro bubbles from, it gives up air very slowly. Temperature and time to get them 100% air free, you may need to add some fluid for a few weeks as it operates.
The Germans call that over size, over pressurization expansion tank a "safety seal"
Remember the pressure gauge will drop when the system is cold, sometimes this gets mistaken for a leak. We get that call on solar thermal, they fill it on a warm day, next morning the pressure has dropped and they panic.Bob "hot rod" Rohr
- 167 Indoor-Air Quality
