corrosion on joints
Does anyone have any idea why this is happening and what can be done about it.
is there a swimming pool or hot tub near by or a janitor that loves him some bleach0
That top picture looks like the corrosion is on a cast iron fitting. Not the copper. The bottom picture looks like the corrosion is on the shut off valve, which doesn't look like brass. Looks like someone may have used the wrong fittings and there is a reaction between the copper and those fittings to me. There is one copper to copper fitting in that second picture that looks like maybe a tiny leak in that solder joint.0
They're soldered.Fred said:That top picture looks like the corrosion is on a cast iron fitting. Not the copper. The bottom picture looks like the corrosion is on the shut off valve, which doesn't look like brass. Looks like someone may have used the wrong fittings and there is a reaction between the copper and those fittings to me. There is one copper to copper fitting in that second picture that looks like maybe a tiny leak in that solder joint.
They're brass.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
They're brass.0 -
it's either your monitor, or a combination of the camera that took the pictures and your monitor.Fred said:
They're brass.
They're soft soldered and you're not going to soft solder cast iron or steel. Silver solder with the proper rod and flux yes but I'm sure that's not the case especially considering all of the propress going on there.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Dezincification was the 1st thing I thought of and then bob mentioned it...0
I would suspect something in the water also, check ph firstBob "hot rod" Rohr
Quite amazing how water is the most universal solvent on the planet........0
And you have a ton of it all through your floors under pressure just waiting to do damage.Gordy said:Quite amazing how water is the most universal solvent on the planet........
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
