AC and furnace replacement Jamesburg NJ
Dave0176
Member Posts: 1,178
Replaced an old Ruud 100,000 BTU furnace which had a badly rotted A coil with a York 95% efficient 80,000 BTU furnace and a new three ton York 14 SEER condenser. When I arrived the basement was flooded with condensate water all over.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
1
nice job....like the transition tooASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company1 -
Ricky Bob, our lead installer, does identical transitions. You 2 must have learned together
I could've gotten them made, but that's down time and more material cost. I pan them in because I don't have a Pittsburg machine nor do I have a Sheer or large break. I got the 4' Malco portable break. There relatively easy to do this way.John Mills said:Ricky Bob, our lead installer, does identical transitions. You 2 must have learned together
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
The return was actually the original return but it didn't line up, that's why the transition was required there.
This house didn't have enough return for a three ton system, the return trunk was only 24X8, good for only 800 CFM, so since the basement is fully finished I added a 10X10 return grill to the return box, good for at least 350 CFM. Plus the furnace is an ECM motor so it should be fine.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
