Slab on grade insulation for infloor radiant?
pesumm
Member Posts: 1
Is using Reflectix for the insulation beneath your slab acceptable? I used 4x8, 2" pink foam all along the perimeter (so there is 8 ft of pink from the wall to the center of the floor all along the perimeter), and then used 2 sided Reflectix for the "center" insulation. All gaps were sealed with reflective tape. I have 4" of pink foam going about 6" into the ground (vertically) all along the perimeter as well, with Reflectix overlapping the gap where the vertical and horizontal pieces of pink foam meet.
The reflectix type insulation works after a fashion for radiant heat. Unfortunately, that's not what you are dealing with underslab, and it won't do any more good than the same thickness of polyethylene sheet would have. Which is to say, nothing. If well sealed, it will be a decent vapour barrier, so it isn't a total loss. Sorry about that...Br. Jamie, osb
- 52 Job Opportunities
