ashrae or man j8
keyote
keyote Member Posts: 659
starting in loopcad is one better than the other i opted to do the cooling loads simultaneously for minisplits later so thats a factor its a 4story 4500 sf radiant heated in nyc ny
  • keyote
    guess its man j if im doing cooling too huh but is it as good for the radiant side or should i just do one at a time
    the program can run both in background if man j is as good w radiant
  • Paul S_3
    Paul S_3 Member Posts: 1,294
    edited July 2016
    heat loss is heat loss whether its for radiant or warm air....i think the loopcad helps you determine whether the radiant will satisfy the heat load or add supplemental heat. i have used the loopcad for multiple radiant and snowmelt jobs great results ....i have also done these jobs without it
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • SWEI
    SWEI Member Posts: 7,348
    Correct, only MJ8 does cooling loads. You can switch between MJ8 and ASHRAE on the heating side. There are some differences in the calculations, but from a designer standpoint the real difference is different climate databases and differing abilities to create custom roof/ceiling assemblies.
