Wooden water pipe
hot_rod
Member Posts: 28,250
Looks like a 10" main and a 2" lateral that fed the building. Rot at the end coupling caused the failure.
At Local 174 in Coopersville, Michigan.
Interesting to see the 100 year old pipe, next to state of the art MIG welders in their lab.
A great training facility and staff, classes are filled up!
Good find HR. Local 501 (now part of 597) we had a piece of wood gas main that had been in use until the early 1990's .
It came from a part of the Chicago area that has (had?) district regulation and low pressure.There was an error rendering this rich post.
I'm told that very long ago LosAngeles had a district refrigeration system with ammonia in wood pipes. Try that today.0
Most likley cypress. So long as O2 keeps away from the wood as you see it will last a very long time.0
A lot of the old buildings in Boston's Back Bay were brick built on pilings back in the last half of the 19th century. As long as those pilings stay wet they will last a very long time, some of them have started to rot because of a falling water table.
http://www.bostongroundwater.org/uploads/2/0/5/1/20517842/ac2008full1977_1.pdf
i assume the water kept the oxygen at bay. I see similar problems with pilings on wharves in the inter-tidal zone.
3PSI gauge0 -
Look at Venice, Italy.....0
Most of the early fire mains were similar wooden pipes. When there was a fire, you dug down to the pipe then bored a hole in it resulting in the pit filling with water under low pressure. Once the fire was out, you took a "fire plug" and hammered it into the hole, thus the nickname for fire hydrants. As long as it remained soaked it didn't leak. Same as wine casks, wooden canteens and wooden boats.1
Here's a couple of snaps I gathered from my home town. I'm hoping there is some more documentation laying around. You manage to peak my interests here at home @hot rod
The Cloaca Maxima in Rome, Italy built in about 600 BC is still in use today. Roman sewer systems were copied from the even more ancient Greek sewers. The aqueducts delivered fresh water by gravity to the royal palaces and wealthy homes; the public had fountains. Poorer quality water went to the baths and the public bathrooms and all drained into the sewer system that discharged into the Tiber River, as it does today. The work of the really, really, REALLY "dead men"!0
And all great empires come to an end. Sooner, or later......0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
