Ridgid black pipe cutter
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
 If it's a 2-A cutter,hot rod said:How tight are the cutter wheels on the pins or axles. If you get too much slop there it will not track properly
 If cutter wheels are still available, maybe the pins are also?
 http://www.ridgidparts.com/rtctable.phtml?id=286
 My concern would be the holes those pins slide into being worse as well.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times. 0
            @ChrisJ i will try the wheels instead of the cutters.... @hot rod there is play between the axles and the cutters they do move a bit...ASM Mechanical Company
 347-692-4777
 ASMHVACNYC.COM
 https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
            That cutter with 3 wheels was designed to be a close quarters cutter. It only needs 1/4 turn to cut all around. It may not be ideal for use with a pipe machine
 Rollers may be tough to find, they are usually narrower for cutter wheelsBob "hot rod" Rohr
 Living the hydronic dream0
            I would definitely look at the pins the cutter rides on. If the pin is worn, the wheel will wobble and tracking will be off. Sometimes you can even take the pin out and rotate it 180 degrees to get by on, as the worn out side is just on the side that the cutter pushes against when it is cutting.
 Or, you do like I do and use a porta band to cut it. I haven't used a hand cutter on steel in a long time. Too much work, and my arms are getting tired. Work efficiently! Also, it doesn't leave a burr.
 Rick0
 You can cut a pipe you're going to thread with a band saw?rick in Alaska said:I would definitely look at the pins the cutter rides on. If the pin is worn, the wheel will wobble and tracking will be off. Sometimes you can even take the pin out and rotate it 180 degrees to get by on, as the worn out side is just on the side that the cutter pushes against when it is cutting.
 Rick
 I tried cutting with a hacksaw, and a sawzall and no matter how straight I kept it, it wasn't good enough for threading.
 REMS has a clever adapter for their recip saws to get a nice straight cut on pipe. I see they have a dual version now, holds the saw and threaded.
 And a pneumatic version recip saw!
 Living the hydronic dream1
            Sure can cut it straight. The trick is to put your eye straight over the top of the blade while you cut it. I can even cut a 3" abs pipe with it even though the throat is only 2 1/2" deep on the saw. Takes more practice though, but most of the time I am within 1/16 of an inch, which cleans up with the chamfer tool.
 I absolutely love my battery powered Dewalt portaband. Very handy tool.
 Rick0
            I'll say the same about the compact 18V Milwaukee we have. It's got a 3-1/4" throat, so 3" Sch.40 takes a bit of finesse, but I can one-hand it, unlike the full-sized PortaBands (whether corded or battery.) Side note: Milwaukee Compact and DeWalt Compact are different band formats. There are not a lot of blade options and they cost a bit more than standard PortaBand blades..
 They also make a cute little M12 model, quite the handy tool if you cut a lot of smaller pipe and strut.0
            I've been giving serious consideration to switching from Makita to Milwaukee, just because the Makita cordless band saw is full sized. And because the Milwaukee radio will charge a battery, not just run on one. But I just bought another pair of Makita batteries, so I guess I won't change this year either. <sigh>0
            I switched a few years ago after dealing with Makita on a defective battery. As I understand it, they are still paying royalties to Milwaukee for the lithium ion patents. When Uponor decided to get out of the tool business and Milwaukee stepped up to the plate it sealed the deal for me, I had no other viable option for the expander tool.0
            Strange, I've had zero battery issues with the Makita. In fact, I still use the original batteries, about five years old now. Let's runtime of course, but I don't even look to see if it's a new one or old one.I had forgotten about the specialty tools, that's another plus. Darn! If I ever got into plumbing for real, I'd pull the trigger for sure, just to keep all the batteries the same. And to keep things slightly on track, maybe some warsher could be used to shim the cutters straight? 0
            Have you heard of the new 120 volt batters packs they're coming out with? They have a built-in charger attached.0
 I think that is Dewalt. They just released that 120 volt battery system which is actually two 60 volt lithium batteries and some of their newly released tools can run on those batteries or be plugged into house current. The charger for that system is also suppose to be backward compatible with their 18/20 volt battery tools. I prefer Milwaukee brand products but Dewalt is my second choice.ratio said:Have you heard of the new 120 volt batters packs they're coming out with? They have a built-in charger attached. 0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
