Steam Radiator Placement
mcp1
mcp1 Member Posts: 86
How far off a finished wall should I place my steam radiator? As of now I have it placed 3 1/2'' of the finished wall, but my wife wanted it closer, so I was able to get it about a 1/2'' off the wall. I feel that is to close to the wall. Is there a standard placement away from a wall?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    So long as it's not touching the wall, you are fine. Otherwise, you will block some of the convective action coming off the hot sections, but the radiator is probably oversized anyway, so you are still fine...
    ME
  • KC_Jones
    KC_Jones Member Posts: 5,928
    It was either on this site or in one of @DanHolohan 's books that I read 2" was standard practice back in the day. He can correct me if my memory is failing me.
    2014 Weil Mclain EG-40
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,696
    That's correct, KC.
    Retired and loving it.
