Handy tool
Member Posts: 4,011
Didn't think I'd need it, but when I saw it at my local builders supply, I just had to have one. Used it yesterday to level a Viessmann horizontal indirect and it paid for itself.
Pumped it up and it lifted the tank up high enough for me to get a wrench on the nuts to adjust the feet.
6
I saw that thing at my local hardware store the other day and had the same thought, Might not need it very often, but would be nice to have when needed... Fire departments use something like this connected to the exhaust pipe of their fire trucks for emergency heavy lifting.
METhere was an error rendering this rich post.
Why didn't I think of that?
Made in Denmark, NICE!
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Is it bad form to ask how much?
The Fire Dept I work for has a few varieties of them, from 4 to 64 sq ft for lifting semi trailers off of cars and such things. We have a large truck-mounted air tank (30 gal or so) filled by either the truck's air brake compressor, a standalone gas-powered compressor, or recharged by shop air thru an umbilical while parked. The smaller ones are like a heavy nylon almost, but the big ones are multiple layers, the outermost being a type of fireproofed canvas.
I have a small one much like the one pictured... I've used it to help level washers, dryers, stoves, workbenches, you name it. In my world at the moment (mechanic/building maintenance) it has a million possible uses.
Besides...who needs an excuse to buy another tool? Snap-On and Matco having charge accounts available on their tool trucks is about the worst thing that ever happened to 20-year-old me....but I still go on the truck every week to see what the 'specials' are. Ha.Ford Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems0 -
Back in the day we did the same thing at the local Sears tool department. Six months after getting out of the army I remember applying for a major credit card, I got refused because of insufficient work history. I had worked for 11 months before going in the army, 3 years at different posts in the army, and six months at a job after the army. I was pretty pissed.
I was in the sears tool department one Saturday morning soon after looking at a 9" table saw, one of the salesmen I knew came over and told me it was a sweet deal. i agreed but told him I didn't have the cash, he told me he could get me a sears store card and didn't think I'd have any problem. I went down to the credit office filled out the form and left with a card that had a whopping $500 limit.
Over the next couple of decades I bought a lot of stuff from Sears so they were well rewarded for giving me that card.
3PSI gauge0 -
They are about $20.00 here: http://www.acmetools.com/shop/tools/winbag-12323rCoany said:Is it bad form to ask how much?
That was my go-to tool when I worked at a garage. We used it almost exclusively to get into locked cars. Slide it between the door and the roof of a vehicle and pump it up. Then you can slide a metal rod in and pop open the door handle, or better yet push the power unlock button! It was even the same brand, made in Denmark.
TSServing Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
