connecting copper tube with corrugated stainless
hot_rod
hot_rod Member Posts: 26,525
Corrugated stainless is commonly used in solar thermal piping. Common connections flatten the end for a gasket joint, or flare it.
Both can be tough connections to seal glycols.
I've found with a 3/4" CTS expander tool you can slide the copper tube into the CSST.
I've tried a few brazing methods with a typical Mapp gas turbo torch tip. Plain brass rod, with flux added also works.
Now you can soft solder the copper tube, pressfittings, compression, etc. into the collector or other piping connections
SWEIkcoppSolid_Fuel_Man
  • warno
    warno Member Posts: 229
    Where I work we make copper to stainless or copper to black pipe connections pretty regularly. I personally don't work in that department by they use an acid based flux with 50% silver solder. After clean up, the joints look beautiful and we test at pressures up to 350 PSI.
    Nice work.
  • njtommy
    njtommy Member Posts: 1,105
    I love using 45%. I use it all the time in refrigeration or comfort cooling.
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Is that a workbench made of old hardwood flooring?
    Steve Minnich
    Grizzly Tool is near me, I drop by their seconds outlet and pick up the damaged tops. 100- 150 bucks depending on size and damage.
    Steve Minnich
  • SWEI
    SWEI Member Posts: 7,348
    Nice work.
    I'm curious how you deal with expander grease on the inside of the CSST?
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Nice! I like it, I've melted a fair share of Harris rods as well. I do love all things brazed or soft soldered, especially if glycol is in the mix. Great tip hr.
    SFM
    SWEI said:
    Nice work.
    I use some grease on the backside of those segments, nothing on the outside. You want to clean both surfaces, belt sander and fitting brush, is what I used
