Steam Radiator Placement
mcp1
Member Posts: 86
How far off a finished wall should I place my steam radiator? As of now I have it placed 3 1/2'' of the finished wall, but my wife wanted it closer, so I was able to get it about a 1/2'' off the wall. I feel that is to close to the wall. Is there a standard placement away from a wall?
The usual distance was 2" off the finished wall. If you're that close, you might want to put an insulating board on the wall while leaving a small air space between the wall and the radiator.All Steamed Up, Inc.
Consulting1 -
Thank you, I appreciate your help.
