Steam Radiator Placement
mcp1
mcp1 Member Posts: 86
How far off a finished wall should I place my steam radiator? As of now I have it placed 3 1/2'' of the finished wall, but my wife wanted it closer, so I was able to get it about a 1/2'' off the wall. I feel that is to close to the wall. Is there a standard placement away from a wall?
    Steamhead Member Posts: 18,205
    edited June 2016
    The usual distance was 2" off the finished wall. If you're that close, you might want to put an insulating board on the wall while leaving a small air space between the wall and the radiator.
    Consulting
    mcp1
  • ChrisJ
    ChrisJ Member Posts: 17,070
    All of mine have the legs touching the shoe molding. If I had to guess, I'd say they're about an inch maybe 1.5" tops off of the wall.
    mcp1
  • Fred
    Fred Member Posts: 8,542
    All of mine are about 3" off of the wall. You should be able to look at the rest of the radiators in the house but I personally would keep them a couple inches off the wall.
    mcp1
  • mcp1
    Thank you, I appreciate your help.
