Bet you've never seen these steam rads
GW
Member Posts: 4,693
Visited this home on a ductless estimate today, had to whip out the picture taker.
5
Art Deco?0
Thats what I'm talking about....! Cant do that w/ FHA!0
Fantastic!0
Not Art Deco. These look like a cross between a Nason and a Whittier. The ribs were an attempt to increase the amount of heating surface. I'd say latter part of the 19th century.
I'm sure you looked and didn't see any name on them............All Steamed Up, Inc.
Consulting0 -
I didn't look, but the people seem to wish to go with me due to a very strong referral. I'll be back1
Yup, you got me on that one! Great find!gwgillplumbingandheating.com
How on earth does that second one work with no top crosspiece? You'd need a vent on every column; that single vent would only allow the air to leave the last column and leave the rest of it air bound.0
I kinda thought that there must be either a continous tube that runs up and back down in each of those towers until it gets to the vent or that each tower has a partition/passage way in it that is open on the top so air can run back down to the base and then over to the vent???Shalom said:How on earth does that second one work with no top crosspiece? You'd need a vent on every column; that single vent would only allow the air to leave the last column and leave the rest of it air bound.
It doesn't need one. This is a steam system. The steam rises to the top of each tube and displaces the air downward, and this keeps going until it gets to the vent.All Steamed Up, Inc.
Consulting4 -
Another odd duck, weirdly hollow in the middle0
Consulting1 -
sure enough, I went to a house today and there were 9 of these (plus more typical rads). Is there an easy to get my hands on edr chart for these?0
If you have a copy of Dan's book "E.D.R.", you'll find the charts in there.All Steamed Up, Inc.
Consulting0 -
thought I did, can't lay my eyes on it.0
ahh found it, sometimes i amaze myself0
Very cool. Found some old Reeds today in an abandoned 3rd floor of a bank where the boiler had been decommissioned.0
Those are much newer. Weil-McLain made them in the 1950s or so- either the Raydiant or the Solray model.All Steamed Up, Inc.
Consulting0 -
almost looks like two wall mounted radiators put together0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
