Wrench for Hoffman 17C
aircooled81
Member Posts: 205
What size socket fits the lid on a hoffman 17c trap?
Thank you, I'll order one up today.
For feild troubleshooting bad hoffman traps, have you seen a infrared temp gun show-up well?0 -
Not for thermostatic traps. The body conducts too well to get any sort of accuracy. F&T traps test well because they always have water in them unless they have blown by so you can ping inlet and outlet temps.
If the steam is off, send the cage units to me and I'll test them for you if you like.
If you have some way to test to atmosphere that's how we do it here. Essentially a trap with the outlet disconnected if possible. You can cycle trap by dumping cold water on it.Peter Owens
SteamIQ1 -
We use a thermal camera all the time to check thermostatic traps. However we aren't really aiming at the trap, we take a reading before the trap, and then aim on the steel pipe downstream of the trap and look for a reasonable temp drop.aircooled81 said:Thank you, I'll order one up today.
For feild troubleshooting bad hoffman traps, have you seen a infrared temp gun show-up well?gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1
