small Lasco 3/4" PVC trap- anyone know who sells these?
GW
Member Posts: 5,137
We use these on occasion on an attic ac, we have the trap outside at ground level. Lone behold, all mt local vendors say they don't stock them (it's probably been years since I've bought them)
Thanks, Gary
Thanks, Gary
GW,
Using Lowes stuff eh?
http://www.lowes.com/pd_51725-1815-HPT507RMC___?productId=3370352&pl=1&Ntt=3/4"+trap
My mind works strangely....I look at that , and think ...that won't work unless the straight part extends down inside it. It wouldn't form a seal.0
Yes I should have rotated the pic, the tip of the pen is where the pipe heads up the side of the house inside the slim duct. The clicker part is where the water drips out. Works nice, does the job and is compact.
I had one of the sales guy stop in today and I asked him if they stocked it. He said no, grumbled a bit with half a smile and took a pic of it, and then asked when I'd be be getting an order with 50 boilers. Gotta start small and work our way up0 -
Lowe's it is! My credit card is accepted all over the place! Thanks, mystery solved!0
Your mind is ok , just looking at a fitting that should not exist.Paul48 said:My mind works strangely....I look at that , and think ...that won't work unless the straight part extends down inside it. It wouldn't form a seal.
hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
