System 2000 and Variable Speed Circulators
GreenGene
Member Posts: 290
in Oil Heating
Hello all
I was wondering if anyone has had any experience in changing out a 007 on a standard System 2000 EK1 with a Taco Viridian or Grundfos Alpha and how you set them up and what you thought.
How is the system piped? Are there zone valves?0
I'm an instructor/ contractor, but I do have one with 4 zones plus an indirect using a zv.
I'm just curious how the EK1 reacted to the change in flow as zv's open and close or just 1 is open, etc because the EK1 heats up pretty quick.0 -
Thanks Robert, personally I don't use the heat exchanger, I use a 1" zv and a superstor indirect, I think the plate can work great with city water but with well I go indirect.
I was wondering with the 1/2" bypass if say a small zone opened the pump would back off, this would slow flow through the bypass and block as well causing it to heat quickly, this could have a positive effect where the block wouldn't drop on the first cycle and shut off the circ while it regenerated, but it could also cause the block to hit high limit, I haven't seen one yet set up so I wanted to see if anyone has any positive or negative experiences.
I'll try to contact someone at the factory as well.0 -
Thanks, the factory said the same, DP.0
For DT now it depends, all 4 zones are different for load 15k - 40k, DT if memory serves runs in the 16-20 range.
Hypothetical question, still using the 007 and haven't seen a variable pump on a EK1 yet, I was wondering what people have seen and tried, what worked, etc.0 -
Good point though, my SS has the 1" cupro-nickel coil and would need full flow and I am 1" all the way to and back.0
I hear ya.0
Thanks0
