Minitube...pump required?
SteamCoffee
Member Posts: 122
Is the Minitube system undoable without a condensate pump? I have been studying the Iron Fireman specs for a while now. Seems with the right math, a proper b dimension can be established, any thoughts?
You can, and it has been done. But you would need a serious business dimension and the lowest operating pressure that you can get away with.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
