Minitube...pump required?
SteamCoffee
SteamCoffee Member Posts: 123
Is the Minitube system undoable without a condensate pump? I have been studying the Iron Fireman specs for a while now. Seems with the right math, a proper b dimension can be established, any thoughts?
  • gerry gill
    gerry gill Member Posts: 3,084
    You can, and it has been done. But you would need a serious business dimension and the lowest operating pressure that you can get away with.
    gwgillplumbingandheating.com
