Radiator expansion noise after valve replacement
JodiMe
JodiMe Member Posts: 122
edited April 2016 in Strictly Steam
We bought the house last summer and had some issues with hammer that have since been fixed (culprit: dirty boiler water). We also had some leaky valves that were replaced. Prior to replacement, the radiators didn't make much noise when heating. Since replacement, they make quite a bit of noise. It doesn't really bother me a whole lot...I'm more curious about it than anything. All those that make noise are the recessed convector style radiators. If that makes a difference... We have one additional recessed one upstairs which did not have a replaced valve and makes no noise at all.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    What sort of valves did you replace, inlet?--NBC
  • JodiMe
    Hm. I'm not sure what you mean. The main supply valves leading to the radiator were replaced on all our radiators downstairs. Every one was either actively leaking or showed evidence of previous leaks.
    They are certainly easier to repair than to replace, because of the need to replace the mating spud as well, which comes with the new shutoff valve. The old spud and new valve may leak, as they are a matched and machined pair.
    Generally, the valves only leak through the packing nut, under the handle, and usually that nut can be tightened down to compress the packing within. That is a lot easier to do than replace the whole valve.--NBC
  • BobC
    BobC Member Posts: 5,556
    I assume this is not a bang but more of a loud ticking noise caused by expansion of the hot pipe? When they replaced the steam valve they may have done something that has the pipe hard against the opening it comes through. Try cutting up a milk jug and work that between the pipe and the edge of those holes.
    What kind of air valves do those convectors have? Venting them too fast can cause problems.
    Bob
    3PSI gauge
  • JodiMe
    You are correct about the noise. Ticking, not banging. I'll try the milk jug thing this weekend! Thanks.
    The vents are maid-o-mists and of course differ in number depending on the size and location of the radiator. I think we've got a mix of 4s and 5s.
  • JodiMe
    Nicholas...they tried repairing hem first but they still leaked. They were in pretty bad shape, to be honest.
  • Goodhap
    Goodhap Member Posts: 36
    Reviving this old thread, as the exact same thing is happening to me now. We had an intake valve replaced in the bedroom (guy did a great job), and suddenly it is ticking like all night long, driving us nuts. Did the milk jug thing work for you?
  • JodiMe
    Oof, I honestly do not recall at this point. We’ve had so much work done on this system since moving in and since this post I can barely remember half of it.
    I would say the creaking from expansion happened until we had a new (and additional) main valve put in. My guess (and this is just that, from 10 years of living with this system) is that there was air escaping/venting through your leaky valve, and now that it’s sealed up, your system isn’t venting enough.
    if you think the noise is coming from the pipes causing friction against the flooring, I would try a metal washer or coin - something that can’t melt. We had that at one point in one location, also, but the hole the pipe comes through has enough wiggle room that we were able to just slightly shift the radiator to be more centered and the loud noises stopped.
    Good luck!
    mattmia2 Member Posts: 16,462
    a piece of plastic in the right place should do it, you need to start by figuring out where it is coming from, it could be the pipe scraping on the floor or the convector element scraping on the cabinet or its supports. it could be water hammer, steam colliding with water trapped somewhere too, depending on the exact sound.
