Hole in a pipe of the Hartford Loop.
HowieRavi
HowieRavi Member Posts: 14
1 pipe oil fired steam in a multifamily. Discovered a hole in one of the pipes of the Hartford loop. Looks like all the piping is welded. Any recommendations for getting me thru the end of heat season? Hole is less than 1cm in diameter. Thanks.
