Tubing ID help please
GW
Member Posts: 5,147
Hello, anyone have an idea on this tube? It was set up with all brass, no iron. It's currently attached to a stand alone water heater. I need to set up a HX or it this is really o2 barrier i can save the guy some money.
Thanks, Gary
Thanks, Gary
Gary ,
Can you confirm that this tubing is not installed in the infamous Radiantec open direct type system ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Rich I don't know what that is, I've always done things the 'normal' way. The home owner has some unusual expression from 'flush and pump' (my best guess at the phrase he used). I didn't feel the urge to quiz him- I always have home owners popping phrases on me i've never heard. Sound like it may be what you're describing though?!0
I just searched that phrase
http://www.radiantec.com/systems-sources/open-system.php
this system has its own water heater. There are two water heaters total (one for heat one for hw). It has an Extrol ST15 exp tank, watts 9D and 1156.0 -
Seems to be the case, Googled it and nothing.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
