Cast iron radiator piping
DBSJr
Member Posts: 4
I have a project where due to space constraints the contractor wants to put the steam supply and condensate return on the same end of the radiator. It doesn't feel right but I'm looking for a reason why it is or is not ok. If the radiator is pitched toward the condensate return, will it matter? will it increase the likelihood of steam hammer orthe radiator getting air bound? Since the radiator will be pitched toward the steam supply also, do I have to worry about getting condensate in my steam supply and a resulting steam hammer issue?
Not sure but I would think since it is steam it would not be a problem as long as the condensate can move out. The steam should work it's way to the steam vent.
I would wait for another response as again I am not sure. If it was water definitely do not do.0 -
If this is a Vapor system, that should work fine. Some pics of other radiators in the building should tell us.All Steamed Up, Inc.
Consulting0 -
There are a number of radiators on the system I care for set up that way -- as long as the radiator has a slight pitch to the outlet, you should be just fine.Br. Jamie, osb
Thanks everyone. It is actually a gravity return system in an old building in NYC0
Gravity hot water? That will work too.Br. Jamie, osb
the rule is that as long as the radiator is not over 3 times as wide as its height you can pipe the steam and return on the same side. Once the radiator is three times as long as it is tall you must use opposite sides.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
I know that's the rule, @gerry gill , but I have a couple which are way out beyond that -- and they still work just fine.Br. Jamie, osb
- 167 Indoor-Air Quality
