another handy new tool
hot_rod
hot_rod Member Posts: 26,574
This was at the Axiom booth at CMX Expo. Claims it will pump up to 30psi. It has a garden hose connector. I like the spiral wound hose also.
Docfletcher
  • Docfletcher
    Docfletcher Member Posts: 490
    Can't find it online. :)
    Hmmmm?
    They had one at the booth, I gave it a squeeze, and this is a pic from the brochure they had. It must be brand new. Check with a rep or Axiom directly, maybe?
    Docfletcher
  • Docfletcher
    Yes, I will do that... Thanks
  • MikeSpeed6030
    MikeSpeed6030 Member Posts: 69
    What is it's intended use? I don't think it is necessary to inject chemicals into a closed, hot-water boiler system.
    It is for injecting conditioners or cleaners into closed systems. Glycol filled systems sometimes need a inhibitor boost, it could be used for that also.
  • Docfletcher
    They don't show the price :(
