another handy new tool
hot_rod
Member Posts: 26,590
This was at the Axiom booth at CMX Expo. Claims it will pump up to 30psi. It has a garden hose connector. I like the spiral wound hose also.
Can't find it online.
Hmmmm?Docfletcher said:Can't find it online.
They had one at the booth, I gave it a squeeze, and this is a pic from the brochure they had. It must be brand new. Check with a rep or Axiom directly, maybe?
Living the hydronic dream1 -
Yes, I will do that... Thanks
What is it's intended use? I don't think it is necessary to inject chemicals into a closed, hot-water boiler system.0
It is for injecting conditioners or cleaners into closed systems. Glycol filled systems sometimes need a inhibitor boost, it could be used for that also.MikeSpeed6030 said:What is it's intended use? I don't think it is necessary to inject chemicals into a closed, hot-water boiler system.
Living the hydronic dream0 -
They don't show the price
