Power Vent Water Heater Photos
Yours, Larry
What an offer!
Every plumber should have a copy of The Water Heater Workbook, by the way.Bob "hot rod" Rohr
Thanks Bob! I'm still looking for photos. Anybody have some? I'll try to make it worth your while!
Yours, Larry0 -
I have a Richmond 50 gallon power-vent water heater...pretty sure it was installed in 2004 and it's still running strong (we bought the house in 2011).
I can certainly snap some pictures if you like...I'll try to post them tomorrow morning.
AndyFord Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems0 -
This is the only one i have missing some things ....drip for relief valve etcASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Do you want simple 1 pipe power vented water heaters or 2 pipe condensing commercial water heaters?0
Hows this???LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com3 -
Amazing what havoc you can create with 3 increasers, some flex, some duct tape and a clamp!Henry said:Here is how not to do a power vent install!
It was the first time I ever installed a water heater, but feel free.
The vent pipe is out of plumb and it still pisses me off 5 years later. The T&P is also slightly off, but I didn't want to mess with it after it was tight. Don't mind the dirt floor.
This is mine...I didn't install it, and I've never had to mess with it. It's a 50 gallon Richmond NG unit...even with my twin girls taking their long showers we don't run out of hot water. The power vent transitions to 3" pvc for the loooong total run of 30" and 2-90*s. And it's sloped down to the outside.
I'd be tempted to replace it with the same when it finally dies (12 years old now) but I have my heart set on an indirect. We'll see how long she lasts - we have really good water here.Ford Master Technician, "Tinkerer of Terror"
Life is now wonderful!! I'll direct my author friend to this thread and see how happy it makes him. JUGHNE, I think we're looking for single pipe venting. Who would like a Water Heater Workbook, or a DVD on hot water or efficient home building? Thankyou All!
Yours, Larry0 -
I know I would absolutely LOVE a Water Heater Workbook to add to my collection!Ford Master Technician, "Tinkerer of Terror"
Goodie! Best to private message me a mailing address and I'll get it to you! Thankyou!
Yours, Larry0 -
Who's picture(s) made the cut?
Hello: My author friend hasn't decided yet, but you posted some good photos! You have a Water Heater Workbook? I'd be happy to send you one!
Yours, Larry0 -
Larry you still collecting photos? If so here's some0
Wouldn't pass inspection here, but every jurisdiction is different.0
Plastic pipe directly connected to heater is a no-go here.
The requirement for an expansion tank is driven by the upstream piping. Any kind of check valve (including a PRV or backflow preventer) upstream and you install one.0 -
This type of exp tank makes sense for DHW, to avoid trapped water stagnating.Bob "hot rod" Rohr
Living the hydronic dream1 -
Yeah,SWEI said:Plastic pipe directly connected to heater is a no-go here.
I'm on city water with no obstructions.
The reasoning behind not running Pex to the water heater was put in place for natural draft water heaters. The Pex would be subject to being too close to a hot Tín flue pipe. This condition wouldn't occur with power vented units.LANGAN'S PLUMBING & HEATING LLC
732-751-1560
www.langansplumbing.com1 -
right..hot rod said:What an offer!
Every plumber should have a copy of The Water Heater Workbook, by the way.0
