Close call
unclejohn
unclejohn Member Posts: 1,833
Customer texted me to say he was at the hardware store to pick up a 3/4 plug for his relief valve so he would have heat. Said no rush come by anytime next week and replace it. I texted him back and told him to search "boiler explosion nanny cam" and that I had one on my truck.
  • BobC
    BobC Member Posts: 5,539
    Does he use a lighter to check the lawn mower gas tank?
    Bob
    3PSI gauge
  • lchmb
    lchmb Member Posts: 2,997
    lighters are for propane leaks..;)
    bmwpowere36m3
  • kcopp
    kcopp Member Posts: 4,628
    Right up there w/ the guy trying to thaw out his frozen car gas cap w a cig lighter.... true story
    Steamhead Member Posts: 18,193
    You can't fix stupid!
    Consulting
  • ChrisJ
    ChrisJ Member Posts: 17,067
    Was the valve leaking because it was bad, or because it was doing it's job?
    What I really want to know is did the customer learn anything from this?
  • ChrisJ
    edited March 2016
    He learned to keep his fingers off the lever on the relief valve....................
    Do you always have to be a total buzzkill?
    You must be awesome at parties. :)
  • cutter
    cutter Member Posts: 312
    Sometimes they work on gasoline
    Many years ago a wooden cabin cruiser was on the Gulf of Mexico and developed engine trouble. The access to the engine was opened and the compartment was dark and smelled of gas fumes. A match was struck to see and find the problem. The gulf was littered with big tooth picks or just plain debris.
  • cutter
