Close call
unclejohn
Member Posts: 1,833
Customer texted me to say he was at the hardware store to pick up a 3/4 plug for his relief valve so he would have heat. Said no rush come by anytime next week and replace it. I texted him back and told him to search "boiler explosion nanny cam" and that I had one on my truck.
Does he use a lighter to check the lawn mower gas tank?
3PSI gauge0 -
Right up there w/ the guy trying to thaw out his frozen car gas cap w a cig lighter.... true story0
You can't fix stupid!All Steamed Up, Inc.
Consulting0 -
Was the valve leaking because it was bad, or because it was doing it's job?
What I really want to know is did the customer learn anything from this?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Do you always have to be a total buzzkill?Hatterasguy said:
He learned to keep his fingers off the lever on the relief valve....................ChrisJ said:
You must be awesome at parties.
Sometimes they work on gasolinelchmb said:lighters are for propane leaks..;)
Many years ago a wooden cabin cruiser was on the Gulf of Mexico and developed engine trouble. The access to the engine was opened and the compartment was dark and smelled of gas fumes. A match was struck to see and find the problem. The gulf was littered with big tooth picks or just plain debris.0 -
- 114 Geothermal
