steam traps
wbjeff
Member Posts: 5
Hi, we are replacing a 100,000 btu steam coil in a duct system. previous contractor had installed a 3/4" float type steam trap on a single pipe steam system with wet returns. Do we need to reuse the steam trap
thanks
thanks
On a single pipe system with the outlet of the coil discharging to a wet return, with NO condensate receiver, but rather a gravity return to boiler, there should be NO trap on the outlet of the heater. However, the outlet should have a vent installed, such as a Hoffman 74. It should be configured so that it is even with the top of the coil.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Here is a picture of it. Shows a unit heater, but a coil would be piped the same.Dave in Quad Cities, America
3/4" sounds large for fractional gpm.
Unit heater manufacturers state that two pipe is required. But I believe that I've seen them used with one pipe. Heater is above pipe and both heater connections are used. I don't think that trap is called for. Generally boiler feed is de-aerated.
The fan controls heater output.0 -
Everone, thanks for the input...jeff0
- 167 Indoor-Air Quality
