Do I have the boiler replacement size correct?
Hello everyone,
I want to be sure I am selecting the proper size steam boiler for my house, and so I came here to ask for you're help.
I have attached the replacement boiler sizing chart for my duplex, and a screen shot of the Burnham Independence Boiler specifications page.
I believe the PIN4PV is the closest size to what I need. Maybe a bit small, but the closest.
For what its worth, I installed 2ea. Gorton #2 vents at the end of the main, and insulated the main with 1" material.
Thanks for your comments.
  • Paul48
    Paul48 Member Posts: 4,469
    You need to calculate the EDR of your existing radiation to size the boiler properly. Do not, just match the size of what is there.
  • vaporvac
    vaporvac Member Posts: 1,520
    I think he did that judging by his attachments. However, his choice, if he wants that particular boiler is a bit "undersized" by current standards. I think they're asking if it's still in the ballpark. OP, are you deadset on this brand boiler, is this what was there or what your installer prefers to put in?
  • Paul48
    Sorry........You know what they say,"Reading is Fundamental".
    vaporvac
  • pachysandra
    pachysandra Member Posts: 3
    Gerry Gill who Dan has mentioned in his books considers Burnham to the cadillac of steam boilers. So that's why I was looking at them.
    My friend is a commercial plumber and we will install it together based on what I want to buy.
    I should also mention that all the radiators are on the first floor. In other words, there is a lot less pipe in the system than if the pipe had to travel up to a second floor. So the "pick up factor" is less because the connected load is less. I believe this size boiler will be just right. But I just like asking for input. You never know what you can learn, unless you ask questions.
  • Paul48
    Sure.......MegaSteam MST 288
  • pachysandra
    That's a oil boiler. I need a gas boiler. but thanks.
  • KC_Jones
    KC_Jones Member Posts: 5,883
    That would still give you a 23% pickup factor. @ChrisJ is much lower than that and no problems. If it's only a single level house I would go for it. I am sure others will chime in.
    2014 Weil Mclain EG-40
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    I'd use it.
    Robert O'Connor/NJ
  • Fred
    Fred Member Posts: 8,542
    I'd go with that too. 23% Pick-up is plenty and the next step up to the IN-5 is way to big. It should work well. Best of luck!
  • vaporvac
    If only they were all this simple :)
