Rusted return pipe on steam boiler
doghouse
Member Posts: 5
I have a closed loop steam boiler with a corroded return pipe that is leaking right up against the back of the boiler. We have a steady drip of water coming out of the back. Will we need to replace the back of the boiler as well or just the pipe? How big a job is this?
What kind of boiler, how old is it? Pictures would help.
3PSI gauge0 -
Here is a closer photo. the corrosion is right up agains the body of the boiler. It was covered in insulation, so went unnoticed for several months. I suspect it started to leak at the end of last season.0
Is this in service now( working)?
You might need to start shopping for a replacement boiler. Who knows what's going on inside.
Good luck !0 -
It is working. The unit itself seems fine, it's just the pipe. Heat up nice, makes no noise. The water is pretty marking though.
Well you can replace the pipe and do a service on the boiler and a thorough inspection.0
Your not going to know till that pipe is removed from the boiler. Getting that pipe out won't be easy but if the boiler can be saved it will save a lot of money.
The good news is you have time to deal with it, good luck.
3PSI gauge0 -
UH, It looks like that pipe goes into a bushing into the boiler. If you're lucky, you may be able to cut that bushing out (carefully)and the tapping threads still be ok. Hope for the best, prepare for the worst.0
Yeah not looking forward to maybe buying a new boiler. It was a slow leak that really did a number on the old pipe. The issue is finding a qualified plumber.
Where are you located?Two-pipe Trane vaporvacuum system; 1466 edr
Be hard to get a guarantee from anyone but is definitly worth a shot at fixing.They make a tap to clean inside of thread but as stated above I would wait for warmer weather.Good luck.0
I repipe a lot of older boilers yearly and there's always risk of once the old boiler has been broken down in order to start the repipe that it's in such bad shape both inside and out that it needs to be replaced. Just as everyone has said wait for the warmer weather to tackle a project like this.0
