Removal of old boiler plugs. Tired of drilling and cutting them out
PhilDavid
Member Posts: 68
Every once in a while I come across bad steam install that has aged a little or a lot. Only one boiler riser when two are clearly necessary, no skim port, ect... So when tackling those old block plugs I do what I was taught. I cut off the square nut, then drill out the center, and finally I cut out a pie slice (being vigilant not to score the tapping threads) and pry out the plug. It works and it sucks... Ugh So I've read guys have had success using an impact gun with 8 point sockets. This sounds brilliant but I'm really freaked out about cracking a block. Have any of you cracked a block removing a plug with an impact? Also if this is a safe and common way to extract old plugs, what size 8-point sockets would I need?
Been using an impact gun for years.
Only quick sure way to remove them unless you enjoy cutting them out. I don't.
Robert O'Connor/NJ0 -
Impact gun to remove 4" and 6" plugs? Dunno.. I have my doubts.0
P
What size sockets do you use and how powerful of an impact?Robert O'Connor said:Been using an impact gun for years.
Yeah me too. I wouldn't consider an impact for any plugs over 2"Abracadabra said:Impact gun to remove 4" and 6" plugs? Dunno.. I have my doubts.
I just ordered 8 point sockets from 13/16" up to 1". A 1" IPS needs a 7/8" square socket. It is the drain port for an old condensate pump.
Impact rated sockets by Proto/Blackhawk that size are about 12-15 bucks each from Total Tool Co.
A 2" ips plug would take a fair sized socket and a good size impact to hammer on it. Again I would always use some penetrating oil several times, then some hammer tapping before impact wrench.0 -
I have an old impact driver that gets used with a hammer, it converts the hammer blow very effectively. I wonder if something like that would work, you would have to use good judgement about the force you applied.
Bob
3PSI gauge0 -
An old timer said you can heat the plug red hot and then throw a bucket of cold water on it and it would unscrew!! I wouldn't try it myself but that would be a good experiment with a junk boiler, as NBC suggested above for impact testing on one.0
If you got the whole area red hot and then put a piece of dry ice on the plug I guarantee that plug would contract.
3PSI gauge0 -
Make sure you have good ventilation, some of those sprays can form some very nasty byproducts. Dry ice is old school but it's pretty benign.
3PSI gauge0 -
I used heat to remove some stuck extol tanks from time to time but also had the scoop Crack when tightening the new tank (by hand) so I'd be mighty leery to do it on a boiler block.0
I think the key is to heat the area around the plug and then cool only the plug, that is why dry ice might be a good option.
3PSI gauge0 -
I'm up for this in a couple days and will post my results.
I'm removing a 2 1/2" top riser tap.0 -
Yes sir0
Great, we will all benefit by seeing the steps!--NBC0
Video is also an effective tool0
Cast iron does not like rapid changes in temperature. CRACK!!!! The sound will haunt your dreams. Drill, cut, move on. Better slow than broke instead of fast and broken.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
I have never seen using heat not work.....0
Finally got to it!
First, I cut the square head off and then cut from the center( hole) out toward the tap threads.
Then I took a hammer and slightly tap the cut pieces
( pizza slice) to break it off. I stuffed a rag inside the hole so none of the pieces fell in.
That was the end of that process.
Here is the pic.0 -
Thank you @Danny Scully Will do!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
