How long for oil from new piping to wash into boiler?
Does anyone have a general idea of how long it takes new piping to get cleaned by steam? Are we talking still oily after a month, or rusty within a day? Today is the last warm day before a pretty cold week so I'm thinking it's the perfect time. I've had pretty short (3-6 minutes) run times most of this season and only a few 10+ minute ones recently due to running 2 CPH.
Just not sure if I should go full blown multiple skims plus a wand cleaning, or just a quick skim for now just in case there is more in the system? I'm thinking if anything, our 15F ambient a few days ago would've given everything a good cleaning and time for stuff to get to the boiler.
All thoughts are welcome!
The piping I did just to give an idea.
Hatterasguy said:
Some people are still skimming after three months................
Beautiful workmanship, BTW.
2 -
The oil actually didn't end up being near as bad as I expected.
I have been having issues with the one pipe rubbing on the baseboard though, I knew that was going to happen. I've had a milk bottle shim in there for right now but I need a better solution.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The oils from the new piping are probably floating on top of the waterline of the wet return, and will not get into the boiler itself, as the water velocity is low there.--NBC0
Sometimes I think some of you purposely try to upset me.nicholas bonham-carter said:The oils from the new piping are probably floating on top of the waterline of the wet return, and will not get into the boiler itself, as the water velocity is low there.--NBC
I really do.
I only suggested that because of my thoughts on the auto-skimmer.
If the oils are trapped there, and not in the boiler itself, then I would think there is no cause for worry.--NBC0 -
ChrisJ, you had commented that your Monitor tops had a oil separator as part of the refrigeration system/circuit. Could you expound on how it works. Auto oil skimming has been of interest to Nicholas.0
Mineral oil is lighter than methyl formate so it floats on top of the refrigerant. GE built a skimmer which is an upside down copper cup. The top of the cup is open to suck up vapor and down a little bit are two holes, one on each side which skim oil off of the top of the refrigerant.
The skimmer is located between two baffles to create a "quiet zone".
Here it is in real life. The dirt is just metal dust stuck to oil film.
Of course, in the case of refrigeration examples, the oil needs to stay in the system to lubricate the compressor, unlike the steam boiler, where oil and "air is the enemy, to be chased away like the raccoons from the garbage cans". This was someone's great statement on here years ago.--NBC0
Slightly different though.nicholas bonham-carter said:Of course, in the case of refrigeration examples, the oil needs to stay in the system to lubricate the compressor, unlike the steam boiler, where oil and "air is the enemy, to be chased away like the raccoons from the garbage cans". This was someone's great statement on here years ago.--NBC
In the case of a monitor top, very little oil leaves the compressor dome as it's not miscible with the refrigerant. However, some does leave, I guess as a vapor or mist and it accumulates in the evaporator over time floating on top of the refrigerant. It must be skimmed off and brought back to the compressor housing where it belongs.
Early 1927 monitor tops didn't have a skimmer and GE didn't even realize there was a problem until I believe several thousand machines were in use for some time. The solution for these units was to defrost them using a pot of hot water as discovered by Fleeta Hoke by accident. GE came up with a better solution shortly after which was to add more refrigerant to those machines, and add a skimmer setup to all future ones.
So, if you're ever on a game show and they ask who was the first person ever to defrost a refrigerator using a pot of hot water, you now know the answer.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Chris - where did you find the little rubber cups for the radiator feet? (at least from the picture they look like rubber).0
They're very similar to these.JimmyNJ said:Chris - where did you find the little rubber cups for the radiator feet? (at least from the picture they look like rubber).
http://www.lowes.com/ProductDisplay?productId=3652689
I originally put them on there because I had to slide the radiator over to paint behind it at a later date, but they didn't hurt anything so I just left them there.
Comes in handy if you need to slide the radiator around and it protects the floor in general.
I ended up buying two sizes, one like the ones in the picture, and the other larger for another radiator with bigger feet, those don't fit as good, but close enough.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Cool - thanks for the link.0
Squick is a standard product we use with every replacement steam boiler. It does a great job of preventing call backs where water quality is concerned. Between the old piping and new oils it does the trick especially when you do the follow up flush after running a few days. Like any additive, make sure the boiler is ok with it.0
I had considered washing the pipe and fittings, and decided the boiler would do it for me. Was just too time consuming to try and figure out how to wash out a 10' length of 1" pipe.
A good washing with a wand and 5 gallons of hot skimming = a clean happy boiler.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I dip the ends of the pipe in the bucket to wash off the cutting oil.. Less is more ....
Same... I then run a rag thru the pipe with a piece of 3/4"Big Ed said:I dip the ends of the pipe in the bucket to wash off the cutting oil.. Less is more ....
Every little bit of oil you can remove before you skim, means less time skimming.0 -
Fascinating.
Time is money so it makes sense to get the oil off before it gets in the boiler.
3PSI gauge0 -
Yeah,BobC said:Time is money so it makes sense to get the oil off before it gets in the boiler.
Bob
And yet for me it was quicker to let the boiler do it. Washing pipe takes effort and time. Skimming, I can go take a nap.
*shrug*Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
As a homeowner your time is your own, if your paying someone you might prefer he does something that is billable.
3PSI gauge0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
