Inventory Questions
greenskin
Member Posts: 1
So I'm new to the hvac business- starting off with my folks' company and learning as I go, and given that the company I'm working for is commercial and residential I have to figure out a lot on my own by trial and error. I'm doing what a lot of companies offer hvac businesses as a team effort, all by my lonesome, but I'm up to the challenge.
My first job here is Inventory- And while it's easy enough writing down what I see, I find myself stumbling over one thing.
Capacitors.
There's a million different kinds, depending on use, voltage and microfarad rating needed, shape, and size. I was wondering if anyone could throw me a line- maybe a list of all the different types and forms of capacitors in use these days? I just don't know what the upper and lower limits are. It'd help me a long way with listing and pricing everything.
Capacitors.
Use the TURBO 200X for dual run capacitors up to 97.5 MFD.....they have smaller ones too....beats carrying 40 different types on truck...i carry 2 small turbos....2 large turbos....and a few misc ones i grab along the wayASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
What will truly work the best, along with what @Paul S said, is to have a database of all components on all your customers equipment. Then you can make sure you have at least one of every type of component needed.
Caps are cheap, just ask your local vendor the top 10 or 15 models they sell. And or just carry some Turbos like I do.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
