What is this thing?
wayngrove
Member Posts: 16
Hello all. I'm new here, and for purposes of full disclosure, I probably (hopefully) won't have another post after this one. I hope this doesn't offend anyone.
I'm in the process of fixing up my house to put it on the market, and one of the many things I want to do is replace the baseboard covers for my hot water (oil) heating system. I'm your typical "Jack of all trades, master of none," so I'm short on names and lingo when it comes to HVAC. I have many options for new covers for most of my house, but I'm perplexed as to the name of this type of heater that's in my kitchen. All google searches have left me frustrated, bringing me results nowhere near what this is. My 3 questions are:
1. What would I call this?
2. Where can find a cover for this?
3. Is this thing too old, beat up or inefficient to the point that I should replace it with something more efficient?
It seems to work normally. I was planning on making a cover, but I can't imagine a plywood box would refract heat well. I also couldn't figure out if this question should go in Domestic Hot Water, Oil Heating or Plumbing, so I went right for the main wall.
Thanks for any and all responses.
That there is a recessed wall convector. They have always been recessed in the wall.... at least all of the one's I've seen.... Your missing the covers.. back and front.
That fin is suppose to be sitting in brackets that are attached to the back cover. The back cover also has brackets on either end (left and right side in the middle) that the front cover either snaps into or gets screwed into depending on the model.
I have never seen them sold anymore. They work great. You could replace it with modern fin, but I really dislike mixing different heat emitters on the same zone. If you do, it will take probably 3X more baseboard (linear foot) to equal the heat output of that convector and you have to put a baseboard tee and vent to bleed it. Really not a fan of modern fin baseboard on a monoflow/venturi system either... which is what you most likely have.
If you knew what the metal cover looks like, you could probably get close to the same idea with wood.
some google pictures for your viewing pleasure:
http://s587.photobucket.com/user/bryankloos/media/Hydronic Heat/IMG_2338-1.jpg.html
http://s1193.photobucket.com/user/nathanbedford00/media/Boiler/_MG_9380.jpg.html
https://www.google.com/search?q=wall+convector&espv=2&biw=1600&bih=815&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiE4p2-qIfLAhXHdx4KHTBIBE8Q_AUIBygC&dpr=1#imgrc=_2 -
Thank you Eric! That is exactly what I needed. I did see one similar to the 1st link, but I thought it had to be different, since that one was inside the wall. I really didn't want to replace it if I didn't have to. Now I can start cleaning it up and look for either a custom cover or making one myself.
Thanks again!0 -
Thanks ghost. I was wondering that as well. I'm thinking it was pushed down by the previous owners' kids and/or my kids standing on it.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
