12 year old Munchkin
Steve Minnich
Member Posts: 2,868
limping along and leaking on the floor as we finish up the near boiler piping and the new Lochinvar WHN installation on an adjacent wall.
Steve Minnich
3
You do great work Stephen....i saw this on mechanical-hub.com tooASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Looks great! Can't wait to see it finished0
Thanks. We do the switchover tomorrow. I can't get a shot of the new boiler and buffer tank yet because it's being blocked by the old boiler and piping. Took this one a little slower giving Tim more and more hands on experience rather than just having him clean fittings for me.Steve Minnich0
That 12 years seems a short life span. Was it badly installed?--NBC0
In my experience, 12 years is what would be expected from a Munchkin. Others may disagree? I would say the installation was poor though.Steve Minnich0
I agree. The water quality on this one is really bad with multiple ongoing leaks, bringing in more and more bad water. We're using Rhomar products to make it right.Steve Minnich0
Beautiful job Steve. Still haven't taken the plunge to switch to propress1
How much time do you think you would have saved using Viega copper propress fittings?0
Thanks again. I have some boiler replacements coming up for schools and churches, that's when I'll be all-in on the press fittings. Although yesterday I wish I was using press. I was soldering in an insanely tight spot above my head that I could barely get the torch and solder to. As I was pulling away after hitting the joint, a drip of solder fell, hit an iron pipe right at face level, splashed and hit my face in 3 different spots. 1/4" diameters burns. I said ouch and kept going : )Steve Minnich0
99% finished. I have to tweak the iSeries mixing valve Monday. 12 hour day today to finish the piping and everything else. Happy weekend!Steve Minnich2
That is some beautiful work you do Steve. I'm the same way always critiquing myself on what I could of done differently1
If the water is iffy there, would you consider filling it with bottled water at least initially?
Rhomar products are effective, but the chlorides, and other nasties are still in the water, even though changed somehow chemically.
Wouldn't that be like fixing the tire without pulling the nail out of it?--NBC0 -
That's a great install. In the area I work in low water cut offs are required and it makes the piping a little awkward.0
Thanks guys.
The bottled water/water quality issue is something I wrestled with beforehand. We cleaned and flushed the system until the water was clear. They recently had huge carbon filters installed so we'll see.
On the top of the boiler there's a brass cross with a probe for the LWCO. I'll pop that in Monday. The old system had leaks everywhere, no LWCO, and always refilling.Steve Minnich0 -
I didn't see that cross - that's better than what I've been doing.0
- 87K THE MAIN WALL
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
