12 year old Munchkin
Steve Minnich
Steve Minnich Member Posts: 2,868
edited February 2016 in THE MAIN WALL
limping along and leaking on the floor as we finish up the near boiler piping and the new Lochinvar WHN installation on an adjacent wall.
Steve Minnich
nicholas bonham-carter4Johnpipejonny88
  • Paul S_3
    Paul S_3 Member Posts: 1,288
    You do great work Stephen....i saw this on mechanical-hub.com too
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
  • njtommy
    njtommy Member Posts: 1,105
    Looks great! Can't wait to see it finished
  • Steve Minnich
    Thanks. We do the switchover tomorrow. I can't get a shot of the new boiler and buffer tank yet because it's being blocked by the old boiler and piping. Took this one a little slower giving Tim more and more hands on experience rather than just having him clean fittings for me.
    Steve Minnich
  • Steve Minnich
    With a little bit of guidance, this is Tim's fitting work.
    Steve Minnich
  • That 12 years seems a short life span. Was it badly installed?--NBC
  • Steve Minnich
    In my experience, 12 years is what would be expected from a Munchkin. Others may disagree? I would say the installation was poor though.
    Steve Minnich
  • kcopp
    kcopp Member Posts: 4,576
    You could conceivably get more life out of a Gianonni IF....
    You pipe it perfect, clean it yearly and have impeccable water quality.
    I am seeing that water quality is a real problem here in the states.
    Steve MinnichSWEI
  • Steve Minnich
    I agree. The water quality on this one is really bad with multiple ongoing leaks, bringing in more and more bad water. We're using Rhomar products to make it right.
    Steve Minnich
  • njtommy
    Tim what's taking so long? At least that's what I would hear. Lol
    Looks really good.
    Steve Minnich
  • EzzyT
    EzzyT Member Posts: 1,367
    Beautiful job Steve. Still haven't taken the plunge to switch to propress
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Steve Minnich
  • Who needs Propress when you can solder like that. Sweet!
    njtommy
  • bob eck
    bob eck Member Posts: 930
    How much time do you think you would have saved using Viega copper propress fittings?
  • Steve Minnich
    Thanks again. I have some boiler replacements coming up for schools and churches, that's when I'll be all-in on the press fittings. Although yesterday I wish I was using press. I was soldering in an insanely tight spot above my head that I could barely get the torch and solder to. As I was pulling away after hitting the joint, a drip of solder fell, hit an iron pipe right at face level, splashed and hit my face in 3 different spots. 1/4" diameters burns. I said ouch and kept going : )
    Steve Minnich
  • Steve Minnich
    99% finished. I have to tweak the iSeries mixing valve Monday. 12 hour day today to finish the piping and everything else. Happy weekend!
    Steve Minnich
    kcoppRJMCTAFO
  • njtommy
    Wow looks great!
    Are you controlling the boiler off of buffer tank set point?
    Steve Minnich
  • Steve Minnich
    Thank you Tommy. I'm almost never satisfied with my own work - always looking for ways to improve.
    Steve Minnich
    jonny88
  • EzzyT
    That is some beautiful work you do Steve. I'm the same way always critiquing myself on what I could of done differently
    201-887-8856
    Steve Minnich
  • jonny88
    jonny88 Member Posts: 1,139
    Beautiful work as always Stephen.
    Steve Minnich
  • If the water is iffy there, would you consider filling it with bottled water at least initially?
    Rhomar products are effective, but the chlorides, and other nasties are still in the water, even though changed somehow chemically.
    Wouldn't that be like fixing the tire without pulling the nail out of it?--NBC
  • Matt_67
    Matt_67 Member Posts: 309
    That's a great install. In the area I work in low water cut offs are required and it makes the piping a little awkward.
  • Steve Minnich
    Thanks guys.
    The bottled water/water quality issue is something I wrestled with beforehand. We cleaned and flushed the system until the water was clear. They recently had huge carbon filters installed so we'll see.
    On the top of the boiler there's a brass cross with a probe for the LWCO. I'll pop that in Monday. The old system had leaks everywhere, no LWCO, and always refilling.
    Steve Minnich
  • Matt_67
    I didn't see that cross - that's better than what I've been doing.
  • RJMCTAFO
    RJMCTAFO Member Posts: 113
    Beautiful work!! I learn greatly from all the jobs that get posted here. All the great technicians that frequent this forum have passed on a lot more knowledge than they may realize. You guys set the bar pretty high.
    Steve MinnichCanucker
  • Steve Minnich
    I learned the same way. Heatboy (Jeffrey Young) really opened my eyes years ago on this site. He did some incredible work. Same thing can said of Ironman, Harvey Ramer, and a host of others here.
    Steve Minnich
    jonny88Canucker
