Spill switch tripping, water dripping at vent pipe seam, steam, humid
JohnRL
Member Posts: 6
in Gas Heating
I have a Weil Mclain gas boiler, a little over 18 years old.
The spill switch trips 15 minutes to a half hour after starts up. There's water dripping at one of the seams in the vent pipe that goes from the draft hood to the chimney. Last night, after it had been running for awhile, I notice steam coming out of the vent hood of the water heater. The basement has been feeling warmer and humid lately too.
I attached a picture so you can see the configuration. I put a piece of foil over the damper motor because the water was dripping on it.
What might the problem be?
Thanks
Thanks
Check that chimney, sooner rather than later. Something may be blocking, or partially blocking the draught. It may be as simple as ice having formed in the chimney (yeah, it can happen) or something more drastic.
Have there been any changes in the operating temperatures of the boiler?Br. Jamie, osb
No changes in the temperature as far as I know.
I had a feeling it might be a chimney blockage. I was hoping I was wrong.0 -
I'm trying to get someone here now0
Does it trip when the burner is running or after shuts down. in the picture the damper is shut.0
It trips while it's running. It was off in the picture0
Yeah, I figured that about the heat and humidity. I have a chimney guy coming at 8:00 tomorrow morning. Tonight we're making do with a couple of space heaters0
Remember that the water heater is just as much of a CO threat as the boiler!!.......you obviously have a partially plugged chimney which it shares.0
Could be a cold chimney. Saw a case like this that the chimney came through roof down by the spouting. When hot really cold could not draft properly.
I also agree with the. Combustion air problem. Can you open a basement window and see if problem goes away. One cycle should determine this.0 -
If it worked before, and does not now there is issues. Most likely in the flue.0
- 87K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
