This one was still running on gravity
We had replaced the old floor-standing expansion tank last year- the original was a D&T I believe, which was a bear to drain. The system originally had an open tank on the third floor- we think the basement tank was installed with this boiler.
And when we got the old boiler out, we found the pedestal it sat on was in bad shape- so we went with a new concrete slab.
The new one is our first Burnham Series 3- a 308. This is similar to the ES-2 series, but is not as finicky regarding chimneys. It has our usual boiler-loop primary-secondary setup, which keeps some warm water returning to the boiler as the system heats up. They did have the chimney re-lined, and we used B-vent for the chimney connector to further reduce the chance of condensation.
Oh, and there was no good place to vent a mod-con.
The last pic is, believe it or not, a very old fuse block. It is mounted on the main beam that supports the joists. I did not see any scorching around it, so they were real lucky back in the day!
Nice work -- as usual. Is the boiler the only appliance using that flue?0
Nice work. Have you tried using the flexible polypropylene chimney vent kits? They make mod-cons easier to vent in this situation, unless there is a shared flue.0
My sentiments exactly
Beautiful Steamhead! What are those old fittings off the top of the American Standard? Some kind of compressible union? Never seen em before...........0
Don, those are Dresser couplings. There was a contractor who put in a lot of American-Standards that way around here, on both steam and hot-water- not sure who they were, but they did a lot of boilers like that.
Paul and SWEI, the water heater also uses the chimney. It's fairly new so they did not want to have to replace that too. Also this is a 3-story house with high ceilings, so developed length could be a factor. But we'd use either PP or SS if we were doing a mod-con... never PVC or CPVC, for reasons I've outlined in earlier threads.
They will get better efficiency from this Burnham.Co-Founder, All Steamed Up, Inc.
steamhead.... would you mind schooling me in something... i thought i should never mix copper and steel in a steam system. i've looked the brunham you used up and it seems to be a steam system if my links/linking were thorough.
where am i miss understanding your pictures?0 -
the above pictures are from a gravity hot water system not a steam system....I think he may of used copper from the equalizer down to wet return....basically below the water line...you should never use copper on the steam header and supply piping....the soldered joints cannot take the rapid expansion and contraction of the piping like a threaded steel joint plus its poor steam fitting and looks unprofessionalASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Great work, it's nice how you cleaned up the area and took time to make the job the best it could be.
Good job to get a testimonial from the owner.Bob "hot rod" Rohr
Right on all counts. This was a gravity hot-water system, not a steam system. And if a steam boiler is piped properly, no steam will ever enter the equalizer, so copper is not a problem there.Paul S said:the above pictures are from a gravity hot water system not a steam system....I think he may of used copper from the equalizer down to wet return....basically below the water line...you should never use copper on the steam header and supply piping....the soldered joints cannot take the rapid expansion and contraction of the piping like a threaded steel joint plus its poor steam fitting and looks unprofessional
Thanks, HR- coming from you that means a lot.hot rod said:Great work, it's nice how you cleaned up the area and took time to make the job the best it could be.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
